How can I set up nokia c3 email pop 3 or iMAP4.
Hi experts
I have just purchased nokia c3 but I don't know how to set up nokia c3 email pop 3. I am interested in the pop3 email setup. Can you please tell me the steps to set it up.
Hi experts
Good day Christopherrsimonn
Not all email services are using the pop3 server, and some uses both pop3 and imap server. The pop3 server download directly to your email client and cleans the Inbox. Enabled the setting in the email client to leave a copy on the server. where imap on the other end is leaving a copy on the server, i.e. hotmail, yahoo.
To get back to your question is that on the Nokia c3, you don`t need to configure the email server settings. It will search for the server ports automatically.
Press menu.
Then highlight mail and press the select button.
It depends on who your email service provider is but I want to show you that you don`t need the server settings for your mail.
Select other.
Put your username and password in.
Now your email is successfully setup.
