Walter Neff
30 points
Posted on - 09/17/2012
I have two desktops in my home. I want to set up remote desktop with webcam viewer with one another. Can I do that? How many PCs can be connected and is there any software to set up the remote desktop with webcam viewer? Another issue is that I have normal webcam so, is there any special webcam requirement or any webcam will do the job?
Thank You for all of your supports
How can I set up remote desktop with webcam viewer?
Remote desktop is very useful to us. Suppose u have a baby and he has a pc. You want to monitor what do he do in pc. For this case u can use remote Desktop. We can use it by using several software and must have internet connection and right hardware. One of the such software is teamviewer. One can stream image to another computer by this.
Another software is fwink. This is an open source webcam software.
You can use "Geovision DVR cards" come with three applications that support remote viewing from computers where the Geovision card is not installed. All three programs come on the software CD that comes in the Geovision box. These software applications are:
Geovision Remote View System
Geovision Webcam Server
Geovision IP Multicast System
Geovision Central monitoring Station
The Geovision Remote View System is used to monitor live surveillance video from the main Geovision system through an Internet connection. The Remote View application is limited to only one login at a time, so multiple PCs and locations can not connect simultaneously. The Remote View Software gets installed on the client computer that will be viewing remotely.
