How can i setup Google Authorship
I want my written content to be my property on my site or other websites. How can i have the Google Authorship.
Sancho,
Setting up Google authorship is a very easy job. This can be done through your Google+ profile. Here are the steps –
1. First of all, you have to put a profile picture on your Google+ profile. That picture needs to be your own thumbnail.
2. A byline of your name should appear on every page of the content, for which you need the authorship.
3. Byline name should match the profile name.
4. Next step, you have to have an email address on the same domain as your content.
A google instructions page will appear. Simply you have to follow the instructions and you will be done. Google authorship not only gives the right to make your content your property, it also acts well in verifying the connections between the contents on the web and their creators. Good Luck.
You can have your Google author ship in only 4 easy steps. Do the following and you are all set.
1. Take a picture with a recognizable headshot.
2. Make sure the by line will contain your name.
3. Your Google plus should match the byline name.
4. Verify your email by going to the link below.
