How can I setup silverlight samples tickets?
Hello, I know silverlight samples tickets added daily in C#, VB.NET, JavaScript, and C++ so check back often. I want to get idea about the setup of this application. Thanks a lot!
Hello Helen,
You will find installation guidelines on Silverlight application in the web. Silverlight applications can be created with your own skills and tools which you find familiar. The quickest way to get familiar with Silverlight is to install Visual Web Developer 2010 Express or Visual Studio 2010. Also install the service pack 1. I have a link for you where you will find a step by step guideline to set up Silverlight sample tickets.
https://msdn.microsoft.com/en-us/library/bb404703(v=vs.95).aspx
I hope this helps.
