How Can I Share Files Between Two Computers With Different Methods?
I have a computer for work at the office and a different computer at home. It is time saving of I can transfer files between the two. How can I share files between two computers?
Connecting to computers can help in sharing of documents and data. It can be of great help for small businesses and family. We can also play network games using the two computers.
Method 1-
Step 1: From http://foldertransfer.com, download Folder Transfer.
Step 2: Install and run it.
Step 3: Click Next after choosing "Send Files to".
Step 4: Click OK after selecting the computer to which you want to send your files.
Step 5: Receiver needs to click on the option of Received.
Method 2-
Step 1: Connect one computer with wireless router or gateway via Ethernet cable and other computers to router or gateway through a Wi-Fi connection to share files.
Step 2: In the Control Panel, select Network and Sharing Center.
Step 3: Choose the option of sharing after right clicking on the folder.
Step 4: Click Start, then double click on the computer name.
Step 5: Type username and password.
