How can i solve (Cartridge) printer.
My printer is Lexmark 2600 . In my printer show me ECG . Now i cannot understand what is the problem of my printer now i can not print any document or picture . Now what can i do ?
 Well, your printer is from a well known brand. Lexmark is a very nice company. But printer is a very sensitive component. There are two types of printer (in personal use). They are: Cardige printer and Laser Printer. You are using Cardige printer. There are many problems occur in the cardige printer. Your problem is a serious problem. You cannot solve this problem yourself. Your printer sensor is damaged. If you have warranty you can repair it freely. Or, you can consult to your nearest servicing centre.
I think you get your answer. This answer might be helpful.
Maybe you have an empty cartridge that's why it was unable to print pictures or documents. Check the printer’s ink cartridges if they are already empty by opening its front panel. If you can’t see the ink level of the ink cartridge, remove it from its slot to better see it. If you do not know how to remove the ink cartridge, read the printer’s manual on how to remove the ink cartridges. The manual is included in the package. If both cartridges are empty, then just replace it.
If the ink cartridges are still not empty and you are having this error, maybe there is a problem with the printer’s driver.
Delete your printer from the control panel.
After deleting your printer, uninstall its driver or application.
Connect your printer to the computer by plugging in the printer’s cable to the computer’s printer port or its USB plug to the computer’s USB port if it is a USB type. Be sure to turn on the printer so Windows can detect it. After it was detected, install its driver next. If the printer was not detected after plugging into the USB port, use all the available ports. If you have already tried all the ports and the computer still wasn’t able to detect it, you have a problem with the cable. Just replace the cable so you can begin printing again.
