How Can I Solve Error 0x80070102
Why does error 0x80070102 occur on Xbox? And what are the simple solutions which can help me to fix this error permanently?
Error 0x80070102 occurs when you press the play button in your Xbox. It is a complicated error that will stop any game user from logging in their account. Such types of mistakes should not be avoided because they may lead to further problems like if you anyhow start your Xbox, then you may get an obstacle in closing it or go to any other option.
To solve this error, you need to first reset your computer and attach your console. Once connected, remove all the extra peripheral devices, then go to apps and load avatar applications. Hold and long-press X button and wait for the output, you may receive a home menu, or an error might appear. Click on settings and check your internet connection, once you finish this sign in again and reboot your computer, this will fix error 0x80070102.
