jamankhan32
Posted on - 09/16/2011
Hi Always I see an error message on Windows Lookup Tool.
I want to solve this problem, but I don't know about this problem.
So I need little help to solve it.
Can anybody help me to solve it?
I attached an image and error message.
"Error # 2002 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Win32/HRESULTS
Status: Failure                                           Code: 2002
Facility: Windows (Non COM)
This Windows style or class attribute is invalid for this operation".
Please help me.Thank you
gmalka
How can i solve Lookup Tool error
This error may cause as a result of software file damage, windows registry damage, and virus or spy ware infection. Sometimes device driver conflicts or hardware malfunction may also cause for this error.
To avoid this error you have to follow the following:
·       Keep Operating system up-to-date.
·       To do regular virus and spyware scans
·       Scan  all the attachments before downloading
So the solution is downloading and installing the repair tool . Then you can fix this problem very easily. You can download it freely.
Actually this error takes place when the system missing its essential files. When a PC is not maintaining properly this type of problem normally occurs.
