I tried to open the application Microsoft Outlook but it failed to do so gives me an error message (like the one in the screenshot)?
How can I solve the issue?
OUTLOOK.EXE-Unable to Locate Component
This application has failed to start because MSVCR80.dll was not found.
Re-installing the application may fix this problem.
How can I solve Microsoft outlook error?
MSVCR80.dll error is an issue with your registry, or it can also be a virus or malware problems or can possibly be a hardware failure.
If it is missing or you need to replace it, do not download from a DLL download page.
It is always best to use from a legit source. Try to recover it if you accidentally removed it. Use a file recovery software if needed. Or you can just perform a System Restore to undo the recent changes that you made from your computer.
It is also best if you will just reinstall Outlook to replace the missing file.
Or run your System File Checker to replace the missing or corrupted file.
Hi Gary,
Msvcr80.dll Errors mean either the file is deleted or corrupted.
Following are some of the ways to solve the problem.
1. Search for the Msvcr80.dll in your recycle bin .If it is there restore it from your recycle bin.
2. Msvcr80.dll error occurs if you use any particular then re-installing program may solve the problem.
3. After installing any new program or making some important changes to the system registry or other system files this problem started appearing .Please perform a system restore.
4. It is possible that Msvcr80.dll is damaged by some virus .Run a virus scan for your whole system.
5. Roll back a driver to a previously installed version if msvcr80.dll errors began after updating a particular hardware device's driver.
6. Perform a clean installation of Windows.
7. Use registry cleanup tool.
8. Install any available windows update.
Hope this will help you.
