How can I solve my motherboard problem?
The system is having a problem in accessing the system memory to refresh it.
Solution:
Him
Once motherboard beeps, this means there is something going on. First, you need to identify how the beep sounds.
Is the beep sound long, short and how many times?
Here's the list of beep sounds and it's descriptions
short beep once    – Refresh the DRAM failure
short beep twice   – Circuit parity failure
short beep thrice  – RAM base 64K failure
short beep 4 times – Failure in system timer
short beep 5 times – Process failure
short beep 6 times – Controller keyboard Gate A20 error
short beep 7 times – Exception error in virtual mode
short beep 8 times – Display Memory Read/Write failure test
short beep 9 times – RAM BIOS failure
short beep 10 times – CMOS Read/Write error
short beep 11 times – Cache Memory error
3 short, 1 long    – Extended memory failure
8 short, 1 long    – Retrace test failed
Once identified the problem, post a comments here and tell us how does the beep sounds in your motherboard.
