mitha
Posted on - 09/16/2011
Hi dear, There are a problem in my Windows system. I need to help solve this problem. I see this error message on Windows system.
"STOP: c000021a {Fatal system error} The verification of a knownDLL failed.system process term the statue of 0*c000012f (0*00112560 0*00000000). The system has been shut down".
How can I fix this problem? Please help me to solve this problem. Thank you
Minra
How can i solve this problem
Your software is not genuine.You must understood and realized already that when your computer doesn't run because of failure of software and closed what have you been felt at that time.You can buy a windows CD or DVD.Insert the disk into disk drive.You should come to click on my computer and you will see the comments for the inserted CD or DVD.Click to the right side of your computer mouse and click on Install.Your software windows will install smoothly.Or if your previous software doesn't work you may bring another software for best performance.
Hi Dear,
Thanks that you have shared your problem with us.
Dear this is a fatal error. It describes that your windows DLL file which is required for it is not reachable.
It may be the attack of virus or the result of inappropriate shut down current time your pc.
Some times bad sectors or bad clusters are generated on the hard disk by un safe shut down.
And all those files which are located on that sector are became un-readable.
Kindly run "chkdsk (Check disk)" utility, it will help you to come over on this error.
If you still face this problem then reinstall windows and make sure that you have formatted the hard disk with NTFS
file system. NTFS file system provides a guard against the bad sector.
I hope you are satisfied.
Thanks
