How Can I speed up my internet?
I have modem and internet connection. My internet speed provided 512 kbps. But According to speed limitation my net connection speed not much.
So How can I speed up? Do you have different technique?
Hello Smith,
To increase the internet connection speed first you have to make sure what is the basic source of your internet connection and how they are supplying you the internet. cable wire or wireless. if that is not the issue than it will be the problems of your system. What are you RAM memory? This is the basic thing which affects all of your computer speed including internet. So increase your RAM and avoid the extra running of unwanted softwares every time because they consume a lot more memory of your RAM. Remove them directly or by going to task manager and end process. Also scan your computer with a good anti virus. Some times virus also generates files on its own to increase the load on RAM.
There are also some 3rd party external softwares which boost up the speed of your internet. So you can also use those.
Thanks
First of all make sure that your modem supports 512 Mbps speed. The modems are designed to run over a low speed and they are not so reliable till now. But you can check in your case does your modem supports 512 Mbps speed of not. You can check this by going to modem properties. I think that this is the major problem in your case and you need to buy a new modem for this reason which will support 512 Mbps speed. Most of modems are designed over a speed of 64 Mbps or 128 Mbps and does not support high speed and that is why you are getting slow speed over network.
The second thing to check is that your service provide is giving full speed to your computer or not. If he is not allowing you to get full speed then you may not be able to access fast internet speed.
Notifications
