Stop Automatic Restart after an update
This is really annoying. I set my updates to automatic so just in case I have forgotten to install some important software, windows will do it automatically for me. But in order to take the changes effect, we need to reboot our computer. And this always happens even if I am in the middle of doing something really important.
I am using Windows XP Home Edition Service Pack 2 32-Bit Operating System. I want to know how to get rid of this automatic restart after an update? I just don't like to see that window which constantly nagging me and as if I have no choice but to restart now. Choosing restart later, then it will pop up again after 10 minutes. Even if this isn't what I want, I force myself to turn off my updates when I am working on something. Then just turned it on after working.
I searched on a site but they said, I need to run gpedit.msc but since I am using Windows XP Home Edition and it does not have a gpedit there, what alternative way can I use to fix this?
Do I need a third party software to do this since my XP Home doesn't have gpedit command on run window?
Automatic updates error
Updating your computer is almost complete. Your computer needs to be restarted for the updates to take effect. Windows will restart your computer automatically on 4:56 minutes.
I need advices. Please help.
