Greg Lewis
40 points
Posted on - 05/02/2013
Hi!
I am using Microsoft Internet Explorer as my default browser. I have set up a home page of a website that I visit every time I start the browser. I am having one problem with it though; every time that I start up the browser, I realize that the home page has changed to something else. Is there a way I can stop home page being changed IE? Thanks.
How can I stop home page being changed IE browser?
Hi Greg Lewis,
I have read the problem that you’re encountering with your computer. This problem might have been cause by an update. Have you updated your Internet explorer lately? If so, this might be the cause of the problem wherein the Microsoft had sneaked in an update to Windows Messenger. So the first thing to do is to disable it, to do so open Internet Explorer go to Tools, Manage Add-ons select Enable or Disable Add-ons and under the list of Enabled add-ons look for Windows messenger and disable it. Now set a homepage of your choice and restart the browser.
-Open your tools menu
-Then click on the Manage Add-ons.
-Select the enable disable Add-ons options .
-Undere the list of enabled Add-ons look for windows messenger,Disable that Add-on.
-Set your desired home page then restart your browser.
If the problem persists then you can block the website that comes up on your IE.
