How can I stream feeds across my Android home screen?
Hello techyv experts,
I have come here for a little issue which occurred in my Android Mobile. How can I stream feed across my android home screen?
I was trying to do this but I could not. I went to another forum but they could not solve my issue. I don’t know if I have come to the right place. Can anyone tell me how I can do this?
Will it need any software to do this?
Answered By 0 points N/A #96239
Hi Voldemort,
You can easily resolve this issue by the following method.
You have to download Bubbleator from https://bubbleator.en.aptoide.com/ and install this.
Then you need to long Press anywhere your mobile screen and go to wallpaper and then select live wallpaper and next select  Bubbleator.
You can see a window where you can set background Image, stream speed and stream location.
If you want to hookup your Facebook or Twitter then go to the settings and select manage Bubbleator items and scroll down and select Facebook or Twitter.
I hope it will be helpful for you.
