hannahwtc
10 points
Posted on - 05/01/2013
Hi there!
I have this document written in Hebrew and I would like to have it converted to Microsoft Office Word. All the installations that I have made are in English and therefore I am not sure how it will handle it. Can someone please advise on how to convert PDF to Word Hebrew without loosing or distorting the content. Thanks big time.
How can I successfully convert PDF to Word Hebrew?
would like to ask if you have installed Adobe CS6 in your computer? this is the newest product of Adobe wherein new features were added including language concern. If you have, you may follow steps below: go to paragraph panel menu(window>paragraph>panel menu and select Adobe Word-Ready Paragraph Composer or Middle Eastern single line Composer. And in creating content for Hebrew or Arabic, enable RTL(right-to-left) text direction our you may switch also to left-to-right text direction. this can be found under character panel menu (still under paragraph menu) ,select Character Direction and choose direction.
There are a lot of online tools and software that can be used to convert documents from PDF to word without distorting the information/content in the document. https://www.pdftoword.com is an online tool which is 100% free that converts PDF documents to word. All you need to do is:
1. Select PDF to convert.
2. Email address where the file will be sent to.
3. Enter a Captcha to confirm that you are human.
4. Your file gets emailed to you and you can download it.
Nitro PDF Enterprise 8 is the best software for the conversion of PDF documents. Nitro PDF can create PDF files, read them and convert them to word/excel. You can get a trial version of it at https://www.gonitro.com/free-pdf-software
