How can i take a screenshot?
I wanted to know all types of ways we can take screenshots of content in your system
Windows Xp and Windows 7 Operating systems
Please give me top 5 free and 5 paid ways of taking screenshots
Screenshots are very useful when you need to show something to a person. Now there are a couple of ways to take it in windows 7 and Xp. Actually all ways are same in both versions. Now I'll show you three steps you can take it from system.
Applicable for both version:
Option A
1. When you want to take a screenshot, just press the print screen button. See the picture for a better idea.
2. Now the screen is saved. Go to start menu and search paint in the box. Open it and Press ctrl+v in the empty space. You will see the image.
3. Now just save the image, and here you go, you got the screenshot.
Option 2
Now in this method you can take only the window screenshot.
1. For this click the window you want to take a screenshot, and press alt+print screen button.
2. Then paste it in the paint and save it.
Option 3 for windows 7 only
1. Open start and in the search box search snipping tool and click it.
2. Now beside new, click the arrow and you can see different shape you want to take a screenshot. Select it and click new and start to mark the area you want to take screenshot.
3. Then automatically a picture of that screenshot will come out and you have to just save it.
These are the possible three way to take screen shot within default. For Software click the link below.
Free version
Paid Version
Hello there,
There innumerable number of utilities on the web to take screenshot. (both free and premium).The top 5 free ways to take screenshot are:-
1. Press the Print Screen Button on your keyboard. Go to Paint and paste it there. Save the image in the format you like.
 2. Open up Snipping tool. It is a free utility in Windows. After opening it simply click on the New tab as shown in the picture. Your screen will go ash. Now drag the the cursor by holding the left-click and you can take scrren shot of your desired area.
3. There is a free software named PicPick to take screenshots. Download it from here. Install it. The user interface is similar to Snipping tools. A picture is given below of it.
4. Besides you can use Fraps for taking screenshots and also capturing videos. Personally I recommend it.
5. Also you can use Graphics card tweaking software like MSI Afterburner and EVGAÂ PrecisionXÂ to take screenshots.
The top five paid screenshot taking software are:-
1. Snagit.
2. Screenhunter Pro.
3. Hypersnap.
4. Fullshot.
5. Anycapture.Â
Check out this Techyv post too to get more idea according to your question.
