How can I take a screenshot in 3d adobe flash
How will I be able to take a screenshot in 3d adobe flash? Give me some tips or tutorial links about 3d adobe flash. If there are some way you can explain me the proper and correct instruction on how to manipulate the software because I am just a newbie in adobe flash.
Thank you.
Best Answer by Harthy Opera
Answered By 10 points N/A #160136
Hello Alanjayason,
In my opinion here is the solution of your problem. First go to Snapshot tool in Acrobat to grab an image of any area of the page, including whatever's shown in a 3D viewport. It would not work inside the viewport but you can drag around it with the help of mouse.
Take care.
Regard,
Harthy Opera
Answered By 5 points N/A #160137
You can look on this link, there a several explanation how to take snapshot  of flash pictures http://www.brighthub.com/internet/web-development/articles/70690.aspx
You can also find a screenshot capturing software, it’s easy and fast to make snapshots. You can try with downloading Jing it’s for Windows and Mac, and is free. Download link: https://www.techsmith.com/download/jing/
I hope this will help!
Answered By 0 points N/A #160138
You can apply another technique too to  take a screenshot in 3D Adobe Flash. Pay a visit this Techyv post and get that technique.
Take 3D Screenshots with Adobe CS5 Flash Application
