How can I transfer tribes ascend copy to a USB?
Hi guys,
I wanted to transfer tribes ascend copy to a usb without downloading the file because the file was very big in size (almost 2GB). How can I get the whole file by coping it to a usb?
Hi guys,
Hello Arthurr,
The only way to get Tribes:Ascend is by downloading from the internet. The creator does not provide another method of getting it such as CD. If you got a slow connection or low bandwidth you can go to an Internet Cafe, download the game and copy it to your USB stick. That way you will be able to take it home, copy it to your personal computer and install it.
I hope that answers your question.
P Vhilary
Tribes Ascend is a Online MP game. Most online games are played by downloading them. They aren't available in CD shops. So find someplace where there is a good internet connection and download the game. Then you can copy it on your USB stick and install it on your computer. If any of your friends have one you can copy it from them too.
I hope my solution works for you.
