Hello Experts!
I have a personal computer running Windows Vista.
I would like to have a sticky FN Vista key on so that whenever I want to have the WiFi set up, I do not have to hold down two keys at the same time.
How can I get about turning the sticky keys on and off?
Thanks for your help.
How can I turn on a sticky FN Vista key?
Here is the procedure to either turn on/off the sticky keys function on windows vista.
1. Got to control panel, find ease of access center and click on it.
2. Click on make the keyboard easier to use, find and click on setup sticky keys.
3. Check on turn on sticky keys (for always on).this will turn on sticky keys even though unchecked above.
4. Click on apply then save.
Note: you can check turn on sticky keys when SHIFT is pressed five times this will toggle sticky keys on/off regardless of the above steps.
 I hope you find this useful.
Hi Hay Lin Liana,
To activate sticky keys on vista the fastest way is to Press the Shift key five times this would toggle Sticky keys On or off.
Remember that this option is turned on in Vista by default.
If you want to make sure that you activated the sticky keys follow steps below:
 Turn On Sticky Keys:
In Control Panel (Classic View), Click on the Make the keyboard easier to use.
Check Turn on Sticky Keys and then click Apply.
Click the link Set up Sticky Keys, this enables you to see other Sticky key options that you would like to be turned on too.
Click Save.
Turn Off Sticky keys:
Click "Make the keyboard easier to use".
Remove the checkmark on "Turn on Sticky keys" and then click Apply.
To uncheck other Sticky Keys, click Set up Stick Keys link and choose which ones to uncheck.
Click Save.
NOTE: If " Turn on Sticky Keys when SHIFT is pressed five times" is checked.
The Keyboard shortcut will still change to on and off.
Hope this helps.
