index1
10 points
Posted on - 09/28/2011
I'm looking for a way to type infinity (∞) and percentage (‰) symbols just using keyboard, i mean without character table.
PS: I'm using windows XP SP3.
How can i type the infinity and “‰” sign on keyboard?
The answer to your question is simple and not hard to do.
For the (∞) Infinity Sign:
1. Your Num Lock should be enabled and then Press and Hold Alt then enter 2 3 6 from you Num Pad located at the right side of the keyboard.
This should solve your problem regarding the infinity sign.
For the (%) Percentage Sign:
1. You can simply hold the Shift button then press 5 located at the top of the QWERTY keys.
Note: This sign depends on the regional settings that your using.
This will give you the solution for the percent sign.
If you have anymore questions, please don't hesitate to ask more. Hope this solves your problems.
Aside from pressing SHIFT + 5 to produce the percent sign “%”, you can also press ALT + 37. Use the Number pad on your keyboard when entering the number combination. For the infinity symbol “∞”, you can also use ALT + 8734. For other symbols that can be displayed using the keyboard, here are several of the combinations:
! [exclamation point] – ALT + 33
“ [quotation mark] – ALT + 34
# [number sign] – ALT + 35
$ [dollar sign] – ALT + 36
% [percent sign] – ALT + 37
& [ampersand sign] – ALT + 38
‘ [apostrophe sign] – ALT + 39
( [left parenthesis] – ALT + 40
) [right parenthesis] – ALT + 41
* [asterisk] – ALT + 42
+ [plus sign] – ALT + 43
, [comma] – ALT + 44
– [hyphen or minus sign] – ALT + 45
. [period or full stop] – ALT + 46
/ [slash or solidus] – ALT + 47
: [colon] – ALT + 58
; [semicolon] – ALT + 59
< [less-than sign] – ALT + 60
= [equal sign] – ALT + 61
> [greater-than sign] – ALT + 62
? [question mark] – ALT + 63
@ [at sign] – ALT + 64
[ [left square bracket] – ALT + 91
[backslash or reverse solidus] – ALT + 92
] [right square bracket] – ALT + 93
^ [caret sign or circumflex accent] – ALT + 94
_ [underscore or low line] – ALT + 95
` [grave sign] – ALT + 96
{ [left curly bracket] – ALT + 123
| [vertical line or verbar] – ALT + 124
} [right curly bracket] – ALT + 125
~ [tilde] – ALT + 126
