How can i uninstall Kaspersky anti virus 2010?
1 year ago I downloaded Kaspersky Anti Virus 2010. Now, its license has been expired. So I went to uninstall it. Unfortunately, I am not able to uninstall or remove it from my computer. It’s creating a great problem as I have to use another antivirus along with KAV2010.It also makes my laptop slow. Please help me out guys
Best Answer by Jay Alvarez
Answered By 0 points N/A #119249
Sometimes you can face this problem.Generally we are follow standard mathods to uninstall or remove Kaspersky from computer.Windows safe mood is the best way to uninstall Kaspersky.If you can not uninstall or ramove Kaspersky from your laptop by safe mood then you need removal tools for uninstall it.
Step 01: Go to https://support.kaspersky.com/downloads/products2009/kavremover9.zip this link and download it.After download complete,you get zip file and Unzip it by any software.
Step 02: Restart your computer and start safe mood for uninstall it.After Unzip complete, you will get karvemove9.exe software.Open it by double click.You will see code and a white box after double click on karvemove9.exe.Now you need put code on white box and remove kaspersky from your computer.After remove kaspersky, you need restart your computer.
Thank you
Answered By 0 points N/A #119248
Here are the steps to uninstall Kaspersky Antiv-Virus 2010. The steps are pretty straight forward. You just need follow the instructions below. This Kaspersky Antivirus is a helpful software that protect your computer from any virus attack. As well all know, how virus works, works and Trojan. It multiply the files into your system and damaged sensitive executable files. It may also steal information from your computer.
First;
You need to quit/exit the application to avoid interruptions and incorrect uninstallation.
* Right click on the icon in the system tray and click exit
* Remove the application, do follow the set-up wizard
Second;
* Click Start, All programs, Kaspersky antivirus 2010
* click Modify, Repair and Remove
* Then the set-up window will come-up
* You need to follow the steps to uninstall the software
Here's the link, this might help you.
https://support.kaspersky.com/2393
