How can I unlock wireless access points for Wi-Fi?
I have wireless access point and was wondering if it is possible to unlock wireless access points for WiFi?
Any kind of help would be appreciated.
Hi
For access points it is same as configuring a wireless router, some how wireless access points are more complex. It is best to configure your access point by connecting the computer with and Ethernet cable directly to the access point. you need to set the IP address of your computer to static and enter an IP address of 192.168.1.1 since the computer will have an invalid ip address if it is not connected to a modem or a router. You may need to reset the access point before you can access the user interface of an access point, depending on what brand of access point you are using you can perform ipconfig on the command prompt to get the exact ip address of your access point. The default ip addresses of Access points is 192.168.1.25 there maybe a username or password after you hit enter.
Default username and password for access points would be admin for the username and password for the password. You need to type both username and password in small letters, some access points have their default username and password underneath them.
