ivonne Lara
Posted on - 10/02/2012
I recently upgraded my Firefox and it says that I can link my card reader to Firefox. How can I use and enabled my card reader. Do I need to download add-ons or applications? Please do help me.
Thank you.
Ivonne Lara
LyanaHay
How can i use and enable card reader Firefox ?
Hi Ivonne Lara,
There seems to be some problem with your system or support software which detects your card. I will suggest you to make sure you have done proper installment for card reader.
Here are some steps you should follow:
1] Check whether you got CD with your card if yes install software available in your CD.
2] If you have already done it make sure you are not missing supporting dll file.
3] Copy this dll file in appropriate location on your disk.
This will solve your problem.
