I need to use android FTP client command application. First of all, I need to have it. How can I have it? I need a free one. Then I need to know its using process. Please, tell me in detail about it.
How can I use android ftp client command app?
Hello Miller,
You can get the application from Google play site. Just go the site & install the apps. This application can manage several FTP configurations. Download, upload, synchronization are also provided in this app. Local or remote option can rename, update, delete or run here. Third party applications are also available. Have a look of the apps screen shoot as an instruction to use.
Thanks,
Akerly Joqw
If you need to use an FTP client on your Android phone, there are apps you can download on the Google Play store that might be compatible with your device. First to try is AndFTP. This app is an FTP, FTPS, SCP, and SFTP client which allows you to manage several FTP configurations.
This is rated 3+ and comes with both device and FTP file browser. The app allows you to download, upload, synchronize, and share with resume support. Another app you can try is SSH/SFTP/FTP/TELNET Advanced Client. This is an all-in-one SSH, FTP, and SFTP client which includes a Telnet terminal. Additional features include monitor your hosts, batch modes, and SSH host monitoring widget.
This is also rated 3+.
