Hi expert,
I need your help as I am facing a problem with synchroarts vocalign software. It provides audio mixing opportunity. But I don’t know how to do it. Please, tell me in detail and of course step by step (give snap shot if possible) so that I can learn the process easily.
Thanks in advance
How can I use audio mixing tool in synchroarts vocalign?
Hello Derek A Rosas,
You have a really good software to use but unfortunately you do not know how to use it. It is not a tough software to use you can easily understand it after reading the attached manual of synchroarts vocalign software. As it is a big software and has so many feature so you can get familiar to its one aspect after reading the attached file to this comment.
