How can I use IRC network of 420-high times website?
I want to use IRC network of 420-high times website.
How can I have it?
Where can I communicate?
Please tell me in detail about it.
Thanks
How can I have it?
Thanks
Dear Robert;
IRC is a multi-channel web exchange talk program that runs on a network. To get an IRC, you need to have an IRC system (Customer). When you want to connect to IRC host, you need to be in the IRC circle. There is a list of IRC networks.
The choice is yours to select.
You can get IRC accounts from spark hybrid platform.Â
Hello Robert Shill,
I am describing you how can you use the network from 420-High Times IRC Network
Wishing you all the best.
Shifflett Laurel
Hi, if you are using IRC, you will need to know a client of IRC and have the software to access the IRC network (server), just like you would use MSN to chat to friends on the MSN network.
MICR is a shareware application, and is also popular client for Windows. You get the trial for 30 days, you need to find and IRC client who works for you. To find one, surf this list of consumers.
To setup your IRC client, you need to refer to your client's records. To connect to the Swift IRC network, type ""/server irc.swiftirc.net"" into the software.
