How can I use my bios set up utilities?
Hi expert,
I need your help. I am a beginner in the world of computer. So, I need to learn many things and of course I’m trying to learn. As a part of my learning, I want to learn bios set up utilities from you. Please, narrate everything very easily as I can realize easily.
Thanks
Best Answer by Samuel J Melendez
Answered By 20 points N/A #159249
Hello Mart
Good Day
So your are new to computer world, i will try my level best to inform you about the best e-learning website, so that you can perceive knowledge in a better way.
https://www.gcflearnfree.org/topics/computers/
This is well known site on the internet which provide all types of computer learning e.g basic,business and internet basics etc. You will also get valuable information other than basic computer skills but subjects strictly related to computer only. Hope this will work for you. Another feature is that you can subscribed for day to day lecture. Daily lessons will be emailed to you regularly.
Thanks
Answered By 5 points N/A #159248
In BIOS Setup Utility, you can be able to manage your computer's memory settings, configure a new hard drive, change the booting orders, reset the BIOS password and more. If you want to access it on your computer, follow the steps below. But be very careful on changing the BIOS details as changes may affect incorrect settings if entered incorrectly.
1. Open your PC and wait for the Entering Setup message just right after turning it on. This is very fast so you need to be attentive.
2. Press the function keys such as F1, F2 or F3, Esc, or the Delete key depending on your computer system. You can see on the bottom left side of your PC which key to press to access BIOS.
