Hello, I Use Windows 7 in My Dell Laptop.
I Am Villagers And I Have Need To Use To Connect Internet Via Mobile As Modem.
I Have Nokia 5300c Mobile Phone And Nokia PC Suite Latest.
But Windows 7 Might Be Not Support My PC Suite Or Edge Modem.
I Have No Another Options To Connect Internet.
So Please Tell Me How I Use Edge Modem And Pc Suite?
How can I Use Nokia PC Suite In Windows 7?
Hello Dowine Johnson, Phone can be use as a modem and have Internet access regardless what Operating System you are using. In your case, you have Windows 7 version and this type of computer has built in software for different hardware, devices and gadgets. Your question is this: So Please Tell Me How I Use Edge Modem And Pc Suite? First, you need to have a cable wire, a USB connection that you need to plugged from your Nokia 5300c Mobile phone to your computer. Second, install the driver/software needed if the auto-detect of a new hard drive won't install. Insert the disc and follow the instructions. Three, this steps requires you to have Internet access because you need to install the driver on to the Internet. See links below for support; http://nokia-connectivity-cable-driver.updatestar.com/en In this article, everything got covered to fix the problem.
Hello Dear,
The Nokia PC suite is the best utility to connect the mobile phones as internet modem.
Here, i hope the driver of your phone that you installed is not correct version or is not supporting by the Windows 7.
In fact, the windows 7 has some new features. Sometimes these new features make problem when we try to run older versions of software.
I think you are using an older version of Nokia Pc Suite.
You should try to use this one.
http://www.softpedia.com/get/Mobile-Phone-Tools/Nokia/Nokia-PC-Suite.shtml
This is Nokia PC Suite's latest version. Specially designed for windows 7.
Try this one.
I hope it will remove your problem and you will enjoy internet.
Thanks
