How can I use or retrieve the Word Art styles from Word2007
How can I use or retrieve the Word Art styles from MS Word 2007 using MS Word 2010? And how do I do the reverse one? I have done this before but I could not remember how I did it.
Many thanks!
Best Answer by Aristono Martin
Answered By 0 points N/A #104226
To use WordArt on MSWord 2010, just go to Insert>Text>WordArt.
Answered By 20 points N/A #104227
Some users find Word Art styles in Word 2003 much better than Word Art styles in 2010. Word Art styles in word 2010 can be accessed if you try to click on Insert a Word Art object then Click on Drawing Tools > Format > Look at text effects > Transform.
You can get the old style back if you save the file you are working in on Word 2003 format then choose Insert Word Art. That would give you the old word art styles.
You may also find the links below useful with regards to WordArt:
Reference Site 1
Reference Site 2
Reference Site 3
Answered By 0 points N/A #104228
When using Ms Word 2010, you will notice that its WordArt is a bit more powerful compared to the previous versions of Ms Word like Ms Word 2003. And therefore to insert a WordArt object, you will just need to do the following:
  • You will go to the main menu and then choose Drawing Tools.
  • Look for Format and click on it, and then look at Text Effects.
  • You will need to choose Transform.
  • That should definitely give you the solution to your question.
In case it does not, then you can still get it using the old style which is as follows:
  • You will need to save the file in Word 2003 format.
  • Thereafter you will need to choose Insert and then WordArt.
  • And then choose the legacy choices.
Mathew Stone
Answered By 0 points N/A #104229
I have read the issue on using and or retrieving the Word Art styles from MS Word 2007 to MS Word 2010. I have options that you can use. You can try going to the dialog box Word Options in either 2007 or 2010, then click Advanced tab, find Show Document Content and check Show Drawings and Text Boxes Screen.
Click on the Insert tab and you will be able to put or access the same word art styles in 2010. If you can’t use this, try saving the file in Word format, and try to choose Insert tab – WordArt so that you can see your choices.
