How can I use Pulse Reader application?
I want to use the Pulse Reader application. But I don't know how to use it.
Specially I want to know is it only for any specific browser?
If yes, in what browser I can use it and how?
Hallo Stacy,
The Pulse Reader Application that was launched with the Newsreader is browser based, and that its slick feed consumption on the internet. What the new web app does is synchronizing the existing pulse application. That means that if there are any subscriptions made in one they are thereafter set up to another, and the Pulse has been working using a browser that has got touch control which is enabled by Microsoft.
The browser you will need to use the Pulse Reader Application is the Internet Explorer 10. It uses the multitouch gestures in internet explorer 10 for web applications and therefore enabling the readers to swipe between articles and as well use two-finger swiped for summoning up the reading list.
Carl
