How can I use revit for master planning?
I need to use Revit for the master planning project. All the image should be 100% Revit. How can I use it? Please, tell me in detail about it.
Thanks
Thanks
Hi Brown Davis,
Revit is software which is used for creating a Building Information Modelling, building professionals design, build, and maintain high-quality, more energy-efficient buildings.
You can use this software for master planning projects. I have attached the images that show some kind of tutorial.
I wish this solution will be fruitful. Thanks!
Best,
Fenster Maxine
Using Revit as a beginner may look complex and difficult. Even opening the application and seeing all those unfamiliar tools can be overwhelming. This is because Revit Architecture 2013 is designed for professionals to be able to create quality 3D objects and architectural designs.
You will not learn too much if you will only rely on forums. It is much better for you to watch tutorial videos in order to make 100% professional objects.
Click this link and it will redirect you to a website that offers CAD tutorials and Revit video tutorials.
