I recently installed a sales letter fonts photoshop which I can I use in photo editing in photoshop. But when I tried to used the font, it won't work. How can I use my recently installed sales letter fonts photoshop?
How can I use the sales letter fonts Photoshop?
Hello Betty,
When you install a font to your computer, it becomes available for use in all the applications you are using on your computer.
Try to reinstall the font and copy down the exact font name which is shown at the time of installation.Restart your computer and Launch Photoshop. Activate the text mode in Photoshop and find the font name in the font list. It must work now.
Hello! Good Day!
Did you put the font file into "C:WindowsFonts" ? If it does it should be found automatically when you start photoshop.
*If you have just install a new font while photoshop is running, you should re-run photoshop so that it will recognize the new font installed.
If still doesn't work. Try to use the font in other application like MS Word or Excel. If it doesn't work in Word or Excel aside from photoshop then the problem is with the font. The font you have downloaded may be corrupt. Download Sales Letter font in another website. Then re-install it.
Hope it helps!
