How Can I Use A Tools Convert Text File To XML Online?
Hi all,
My boss has given me lots of Text Files, and he has asked me to convert all those files to XML within two days. There is no certainty that I will find a tool to convert the data quickly. I need someone to recommend a tool to Convert Text File to XML Online.
Answered By 15 points N/A #160378
If you have many files and not much time, then I would suggest you to go for Convert Cat. It is an online tool with the easiest user interface that can allow you to convert Text Files to XML quickly and for free. To use the tool; you have to visit https://www.ipset.in/.
When you open the Webpage, you will find a button to upload the file that you have to convert. Click on the “Choose Files” button, and Upload the Text Files. From the Drop-down menu of “Extensions Available”, choose XML. Enter your Email Address, and click on the “Convert” button.
That’s it. In this way, you can convert all your files without a problem.
