How can I use Virtual Keyboard in iPad Air
I have seen many Chinese Tablets using virtual KeyBoard with them. I have iPad Air and I want to use the Virtual Key Board with it. It becomes easy to type with that one. How can I use a virtual KeyBoard with iPad Air. Do I need some device drivers? Will this be possible?
Answered By 0 points N/A #148726
Hi Avery Brandonn,
I'm more than happy to assist you. I recommend The Logitech Ultra Thin Magnetic Clip on Keyboard Cover for the iPad Air. The instructions for set up are as follows:
1. Place your iPad into the slot provided in the keyboard cover.
2. Turn on the keyboard cover
3.Establish the Bluetooth connection by turning on the Bluetooth on your iPad air. Select "Ultra Thin for Air" on your iPad's devices menu.
4. Adjust your iPad to suit your viewing angle.
5. Enjoy!
