How can I use a Webcam with Ubuntu OS?
I am a new user of Ubuntu. I want to use a webcam with Ubuntu OS. When I try to connect my webcam in PC’s USB it is not shown in my Ubuntu desktop. There is no message shown here. What can I do now?
Hey Luice.
Here i will tell you how to install Web cam on Ubuntu Operating System step by step.
Hope this will help you.
Regards
Cathie.
Ubuntu provides two kind of function named ‘out-of-the-box' or 'just-works'. Just plug-in your webcam and use it. There is no driver disks or installation. To test webcam works in this way, install Cheese.
At first you have to open the terminal window. Type the following command into the window
“sudo apt-get install cheese”
Think it should HELP you.
