How can I view .shx files on Smartphones?
Hello guys,
Can you tell me how I can open the .shx the cad file on my Smartphone. Is there any special software/app available to open the .shx file?
If yes, then please help me with details like the software name and also the link from where I can download.
Best Answer by Reginald E Cosentino
Answered By 0 points N/A #131413
Hello Greg Lewis,
There is not any such type of file viewer for Smartphones. So, you must use the Computer to view it. But in computer, you must use a software to open and view it.
You can use the Shape Viewer application to view it. It's supported on all Windows platforms.
Now enjoy it.
Answered By 40 points N/A #131414
First of all, it is possible to open the .shx file to your Smartphone.
Secondly, follow this link:
http://www.easyfreeware.com/shapeviewer-194367-freeware.html
To download above mentioned file (named as shape viewer 1.2 for smart phones) in your laptop/desktop/smart phone.
Finally, install the downloaded software on your smart phone and browse your desired cad files.
It is to be mentioned here that the size of the software is 35.0 KB.
