How can I view the source code of any web page?
Now in a day we need to browse the web page several times.
Is it possible to view the source code of any web page?
It is possible to view the source code of any web page.
I should explained to you how it possible in different major browsers. It is important when you are viewing the source code of any web page that only information and code is not processed by the server so you can view the code used to generate the result page but you cannot see the source code. If you use Microsoft internet explorer to view the source code following steps.
Open internet explorer and click to view and from the drop down Menu click ‘’Source’’, If you use Mozilla Firefox you con follow the same steps.
Thank you very much.
Hello Lincon,
For sure it is possible to view the source code any web page, but the only thing that you cannot do while viewing the code it editing or making changes to it because the code has been right protected, or it is in the read only format. It does not matter which language the web was designed in, be it Dreamweaver, Joomla or html, you can view the source code for all of them.
Just do the following to view the source code of your web page:
Regards
Mahesh Babu
