How Can I What Are Microsoft Excel Functions? Help?
How do I get to know microsoft excel functions. I don’t know them, and I will be glad if someone told me what they do.
Hello, you have a conceptual problem, the solutions for it is,
Or
Just go through the brief description below-mentioned.
Functions in Excel are the predefined formulas which are present in the software.
If a calculation is present in a cell and there is same calculation that is to be performed on the cells then, using excel functions we drag down the cursor from the corner of the cell then we can use it similarly for all the cells up to which we drag the formula cell.
I hope one of the above methods will help you in solving your issue.
