Jose M Quam
Posted on - 01/13/2015
I have images on cancer and would like to write the Image code sequencing to enable it to identify the stages of cancerous cells form other photos, How can I achieve this? what is the nature of this code? is it Java, C# or a simple line command? where can this code be found?
How can I write a MATLAB code for Image Analysis?
Hello, Jose!
I suggest you to use Matlab coder and you can find how on this following link: https://in.mathworks.com/products.html. It's highly efficient in conversion of Matlab code to C or C++. It's highly flexible as that of Matlab and includes all the features of Matlab like functions, Matrix representations. Once you go detaily through the link mentioned above, you will find out more on this.
Mathew Tand
