Chase Dean
Posted on - 01/19/2012
I am trying to create an animation through Cinema 4D Studio. The frames per second should be 25 with 32 bit depth. I will use the animation online. The issue is the quality for rendering the video is not smooth. There are also some freezes. I used other codec’s to test this but I am unlucky. The animation is 1280 x 720 Square Pixels. I don't have any problems with other things except when rendering. By the way I am running MacBook Pro. Please send me some help as I do not want to start my work again from the start. Thanks.
How can my C4D animation run smoothly?
The problem as to why the video that you created using the after effects application does not appear to be smooth is because of the following;
The screen resolution may be low and therefore making the video look blurry. You will need to access the screen resolution settings and change them to high and see the effect they will have on the video.
If not the screen resolution, they may be the resolution settings that you have configured to use in your After Effects application. And therefore you will need to access the after effects tools and then change the resolution settings to high and see if that will improve the appearance of the video.
-Experttechyv
