lj rivera
50 points
Posted on - 01/12/2012
NcFTPd is listening to all IP address for the PC. It will be good if it can configure the NcFTPd to listen pre defined addresses. How can the NcFTPd can utilize more than one network interface in multi-homed PCs?
How can the NcFTPd utilize more than one network interfaces
Hi LJ,
NcFTPD is an enhanced FTP client which can automate many login steps with FTP with its additional features. It runs on a large number of platforms and displays a command-line user interface. It often provides a first exposure to bookmarks and automatic use of binary transfers.
Yes we can definitely use NcFTPD Â to utilize more than one network interface card. What we need to do is to set up each IP address a separate domain in the domain.cf. You may try to use one domain entry being the IP address of the Ethernet adapter and another IP address of the loopback which is 127.0.0.01
Aristono
