How can old keyboard be felt in my android tablet?
I miss the old keyboard I have with my old phone and laptop, Â will there be a new app for my android to better handle the feel on the keyboard? Â Will this be available for my android tablet?Â
Kristi there are two type's of keyboard socket is it a Ps2 or USB? if it is USB type it should be supported by android all keyboard usually works in plug and play it should be working just plug it. if it is not detected restart your tablet while keyboard is plug or try to look at any controls might be related to keyboard hardware..
Yes there are few best keyboard apps available similar to the keyboard which you used to enjoy with your old phone and laptop.
Please refer to the following links to the Google Play Store:
1. Touch Pal Keyboard is the one of the best app available on Play Store. You can download it from the following link.
2. Swift Key 3 Tablet Keyboard is another very good keyboard app. Download it from the following link:
I hope it will help with the same old feel.
