How Can One Solve/fix The Problem Of Error Code 404
Hello, I am a new computer operator, and I cannot find what I was searching, and it shows regarding error code 404 on the screen, can you help me in solving this problem.
About This error code 404, firstly it comes when the page you are searching cannot be found on the server. You can refresh the page first; then you can go for clearing the cache and cookies and should check whether the Url has been written in the correct language, then you can go for searching the malware. If now solution got to be found them you can go for Prestashop. But before that, you have to backup your data. See the access to permission may be that would have been disabled so enable them.
A “404” error indicates that the page or content you are trying to access is not available or cannot be found on the server. You normally see this error on a web browser when visiting a website. This can happen if the page you are visiting has been deleted, moved to a different location, or the HTML or PHP file was renamed.
In websites, this HTTP status code may appear in many different ways because it can be customized by individual websites. You might see it as “404 Error”, “404 Not Found”, “HTTP 404 Not Found”, “404 Page Not Found,” and more. If you are entering a link on the address bar of the web browser manually and you misspelled it, it will trigger a 404 error.
To troubleshoot the problem, check that your internet connection is working. Unplug the network cable from the network port at the back of your CPU then plug it back in. Open your web browser and visit a website then try clicking some links. Verify that your internet connection is working. If this doesn’t work, disconnect the other end of the cable from the Wi-Fi router and connect it back.
If this doesn’t work, restart your router. If your router has a power button, press it to turn it off then unplug it from the power for about ten to twenty seconds (10 to 20 seconds). Press any button on the router to discharge any leftover power or to power cycle. After this, plug the router back to the power and turn it on. See if this works.
