How can Open Facebook ID in my computer
Dear Mehedi,
You can open the Facebook ID from anywhere. It is free and any one can join it. If you are not able to open the Facebook website, try some other browser to open it. Another way is you can try to make an account from your mobile. This will help you. The website for mobile is: https://m.facebook.com/.and if you are using a touch screen you must enter: touch.facebook.com.
Try these one out to set up a Facebook account.
Hi Mehedi098,
Is the problem you not being able to log in on Facebook or you can't access the page at all? If you cannot log in, try checking if you have put in the correct email address and password. If this is not the case, then I think your company has blocked the use of Facebook in your office. Try using a different browser and check if this is the cause of the problem. If not, also try updating the browser you are using as well.
Although it is very easy to create an ID at Facebook but for this purpose you may an active email account with Gmail, Yahoo, AOL or any other service. Now by using your already created email address you can create an ID with Facebook very easily.
If facebook is not opening on its own website then you must try to open it on web browsers, if thats not working,then u may have done a mistake in putting your email id or password, if this is not the problem then try log in to this proxy website www.thefacebookproxy.com
Opening a Facebook id is very simple. First create a email id if you do not have any. If you have, then go to www.facebook.com. On that page, fill up a form with your details like Name, email id, password, sex and date of birth. Then you will be registered as member of Facebook and you have a Facebook id too.
Open an ID in Facebook at first visit www.facebook.com. Then you sure your Name, Email ID and password. At last you have a mail in your email address and if you verified this link your Facebook Id is creating then you login your ID. For log in your facebook ID your needs your password and Email id which you made. Thanks
