I have two tables of values.It returns true it all tables contain the same data and for different value it is false. But I don't know the way how oracle tables sql data compare with each other? please let me know.
How can oracle tables SQL data compare with each other?
Hi Garcia ,
Try the bellows query, may be it will help you
(select * from Table1MINUS select * from Table2) UNION ALL (select * from table2 MINUS select * from table1);
After executing this query the output will returned few rows , we know that data on both tables have identical . So rows which will returned by this executing the query present comparison between the table1 and table2 tables.
Thanks
Patrick Opal
Hello!!
I have got the point of your question. This is very significant to the database admin.
I can give some hints about the solution.
You can compare your data by sql query. The most effective conditional statement is ‘ SELECT’.
By which you can start filtering your data.
You must use the where clause to filter a data which is to be compared. The WHERE clause
Denotes criteria that will be matched the condition before query.
By query you can compare your sql database tables.
Regards
Shifflett Laurel
