How can I reinstall Oxycube trial version
i download the trial version of oxycube and after 30 days it was expired how can i reinstall it  show me the way please
Try the following things.
You can download the software from the CNET website, just click on the link below:
http://download.cnet.com/s/oxycube/
This is a very old software. You should also try MyPhoneExplorer. I am using it and it is one of the best out there. Just install the client version on both the PC and mobile phone. Connect your mobile via usb or bluetooth to your PC and problem solved. Here is the Download Link
I’m not sure if there is a way of resetting the initial install of the program on your computer after it had expired because most of the time, when a program expires or reached the time of their expiration, the program won’t let you reinstall it on your computer. It’s like when you uninstall it and then install it back it’ll still detect the first installation with expired trial period.
It’ll finish installing but will end up deactivated because of the original installation. There’s usually no solution to this even if you clean your Windows registry. But even if most trial programs are like this, not all do this and there are still others that will let you reinstall it and start a fresh trial period.
To know if your program is one of these, uninstall it from your computer since it is already expired. Click Start, Control Panel, and then Add or Remove Programs. Find and select OxyCube then hit Remove or Uninstall and restart your computer. After booting, try running its installer again so you can see if it’ll allow you to reinstall it.
If after the installation and when starting the program it turns out deactivated, then it means it doesn’t allow reinstalling. It’s either you purchase a license for it or install a different version. To download a replacement for your OxyCube, visit OxyCube Developer: Oxygen Software.
