How can run WarOnline DB with SQL Server 2008?
20 points
Posted on - 08/13/2012
Hi all
I utilize ep3.3 db as well as war0nline newest db but similar error, war0nline db only run SQL server 2012 other than how can I work SQL server 2008. Need your suggestion.
Please help.
![](https://www.techyv.com/sites/default/filesx/users/Images/Microsoft-SQL-Server-Management-Studio.jpeg)
Microsoft SQL Server Management Studio
Restore failed for Server 'AHMET585SQLEXPRESS'. (Microsoft.SqlSever.SmoExtended)
Additional Information:
-> System.Data.SqlClient.SqlError: The database was backed up on a server running version
10.50.1617. That version is incompatible with this server, which is running version 10.00.1600. Either
restore the database on a server that supports the backup, or use a backup that is compatible with
this server. (Microsoft.SqlServer.Smo)
                                           OK
