How can setup dual boot two operating systems?
How can setup dual boot two operating systems, each on its own internal hard drive? I need full setup process can any one help me how to setup it? Is there any problem I face in future if I setup it?
To set up dual you have to do the following. If you want to install two operating system on your hard disk first suppose you want to install window XP and Linux. First install window XP on your hard disk to install window XP it is more easy and very simple task. Insert window XP CD/DVD on you Rom. And boot you compute from cd room then select the partition in which you want to install your window XP and then next when installation complete.
Now insert your Linux cd into your cd room and boot again from you cd room and select different location than you have selected for window XP. And install it Now restart your computer and it will display two option to load which operating system to load select which you want and click next.
