How can setup home network with 5 Computers?
Yes you can. You can make you own home network system it is not really so hard though you need some instrument. Now as I know there are four types of network you can create they are 1.peer to peer 2. Basic Ethernet 3. Basic network with modem internet. 4. Basic network with broadband access. First two allow you to connect all pc that you have in your home and the last two allow not only connecting but also allow you to access internet. And for that you need a modem or a router or a broadband connection you can use LAN card to easily connect all your pc then easily connect them with the modem now for more information you can visit this site https://www.computerhope.com/issues/ch000469.htm
Hello James,
To set up the home network, there are several components that you will need to get. The following are some of the basic components that you will need:
Once you have all that, the ISP support staff will set for you the network and you will be good to go to use the internet at home.
__
Regards
Mahesh Babu
Notifications
